Jim
I once installed a Carb and had the small vent hole on the manifold covered by the gasket (back wards). The engine ran up to about half throttle and then ran out of gas. If you engine has that small passage from the block thru the manifold to the carb it must be clear to allow the air flow it requires. Just another late night thought.
