Front and rear fuse sections mated together.
Front fuse servo wires and air lines ready for connection. Lines routed behind air tanks and tucked into the inside of the front fuse wing strakes.
Projet Hornet ECU mounted on left side of center fuel tank. Emotec 740 HV smoke pump mounted on right side of center fuel tank.
Wires and air lines run from front of fuse to rear section on left and right sides. ECU battery and air service panel under nose radome. Switches will go there also.
Front and rear fuse sections finally fastened together with 8 bolts. Initial tests show that all servos are working properly.
Paper towel flag on pitot tube screw shaft to keep me from breaking it off moving around the table.
Air system tests next.
