Originally Posted by
foodstick
I think typically you only use the battery plug in for a separate on board receiver pack. If you are using a Speed control with a BEC then you will leave the battery slot open.
I am not up to speed on every new thing out there but I think this the answer you are looking for, hope it helped.
Thanks for the reply! Im not sure what the problem is. I got the whole kit from FliteTest except the receiver and transmitter. I know they should work as they came together, but I have no idea why they don't! Im also from Iowa btw. Thx for the help!
