RCU Forums - View Single Post - E Z Arf Models
Old 08-16-2016 | 02:32 AM
  #359
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Originally Posted by go_hercules
I like the idea of extending the rod beyond the Y. I will see if I can squeeze that in. It's really tight on these EZ arfs. The other thing that bothers me (because I'm picky) is that when you run the pushrods out to the elevator halves, they push the control horn at an angle to the hinge line which induces a twist in the rod and control horn. I know most people just live with it but I was thinking of maybe putting a ball joint or something there.
Just bend the rods out, then back in to line up with the control horns,, like a large Z-bend, that takes all the side force out, the wire is still plenty stiff with the bends
This is a long proven method used on much higher performance planes that the Chippy, you'll be fine
good luck
