RCU Forums - View Single Post - Large Skymaster Hawk build
Old 08-18-2016 | 04:46 AM
  #605
DelGatoGrande's Avatar
DelGatoGrande
My Feedback: (23)
Originally Posted by Gary Jefferson
Can anyone explain why this Hawk has a tendency to bounce on landing sometimes. I haven't figured out if it is c.g. related, letting the nose drop too much on landing, too slow on landing, or something else. Anyone else seen this on the hawk. Once it starts it doesn't want to stop.
If its happening "sometimes" then you are touchdown too fast this times.
You may also want to check your wing incidence as it might be too "positive".When you look your model from the sides the wing should be parallel to the ground.
Check the oleo legs .If your mains are empty for whatever reason, then your nose leg holds your wing at positive incidence and cause it to bounce.
I never had a bounce landing with the Hawk.
my 2c
