Originally Posted by
serious power
Hi,
I think you misunderstand 'P' effect.
It is not about high angle of attack - it is about changing angle of attack - in all directions.
The faster the change in direction and the more power that is applied through a single propellar the more 'P' effect is experienced.
In pattern we are constantly changing direction in both pitch and yaw. P factor is in play.
Brian
I understand P factor, but my wording could have been better.
It is about high AOA as well as changing the AOA and It's also about the AOA relative to the flight path.
P factor does have a greater affect with faster direction changes. Even though we change directions a lot in pattern, we do so gently and smoothly which will not have anywhere near the same effect as in 3D for eg. Push and pulls are performed while applying elevator and adding power smoothly, which doesn't really fit the criteria for P factor.
My opinion of course from my experience.
