The esc is not the problem.
What radio and receiver are you using?
My guess is the placement of the receiver and antenna inside the airframe. If the receiver and antenna are at or below the waterline you will loose or have diminished radio control the farther out you go on the water.
Try relocating the receiver so you can get at least the antenna higher up in the airframe.
