RCU Forums - View Single Post - Cox .049 engine and guillows planes
Old 08-20-2016 | 05:19 PM
  #60
idkaname
Originally Posted by JohnBuckner
Can,t say about the plastic disc unless perhaps its a replacement for the stock Cox. Not absolutely sure but I do not think Cox made any diesel fuel. I seriously doubt the fuel he is ordering is diesel fuel which you must have and by the way also you cannot substitute automotive pump diesel.
Never run any of the Davis heads but got one for an OS 32 hanging on the wall The 6x4 prop should work well on your engine.
John
Hmm. Well idk what to do about that.. I guess I could get a glow plug and put on there? As for the diesel thing. The engine has an adjustable compression screw and it seems the disc would interfere with the adjustable compression. Well, it does look like it has burn marks so maybe ot was run like that? Anyways, I could make my own diesel fuel. Just idk where to get ether or castor oil. I know the "diesel" fuel, according to cox, is ether, castor, and kerosene.
