RCU Forums - View Single Post - insulating
Thread: insulating
Old 08-21-2016 | 03:35 PM
rt3232
Originally Posted by JohnBuckner
Jetmech is absolutely correct and 2.4 receivers should never be fully wrapped. They definatly do not like the heat this caused lots of problems when the fellows first stated cocooning them in foam like the old 72 stuff and this caused many failures.
On everything I do on up to jet turbine is to simply use Velcro This also provides plenty of vibration isolation. The hooks just ca'd to back of the receiver and the loops ca'd to the airplane. Don't depend on just the stickem on the Velcro.
John
The above is absolutely correct, but just be safe I have been using a sticky 3M tape ware you peal off the film from the up side stick your parts together and to date I have not had one come apart
Just my 2 pennies worth
Cheers Bob T
AMA13377
