RCU Forums - View Single Post - When The High Speed Needle is fully closed...DOES IT DO THIS? WEBRA 55
Old 08-21-2016 | 03:48 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
If the needle was over tightened, it may have wallowed the seat out some. Try to tighten the needle a little tighter and see if fuel stops.
I don't think this problem would cause fuel to spit from the carb when running unless the needle setting is way too rich or the engine is running backwards.
