thank you guys...also, i had forgot to mention that the engine was fully "jammed"/mucked up, especially the carb prior to geting it back started over the weekend....what i did was boil it in water and that released up everything to an extent.....any idea if this could have messed up the carb?
Originally Posted by
1QwkSport2.5r
I don't think this problem would cause fuel to spit from the carb when running unless the needle setting is way too rich or the engine is running backwards.
i think its spitting fuel because the needle is completely not functioning.....therefore the fuel is going in to the carb at "full open" even when it has been literally been fully shut
-edit- please refer to the posting below....the needle is not at "full open" when fully shut but/however is letting in some air/fuel in at fully turned shut.
