Originally Posted by
MaJ. Woody
Congratulation on the maiden Tom!
These are the same gear I am looking at...the Pro version. Did you buy the Data Terminal or just setup from the controller? How do the Prolinks connect to the retract units? Is there a connecting pin? If so I may want to purchase some spares in case they bend. Thanks again!
I bought the Data Terminal. It makes setup WAY easier! I spec you could use the light on the Xicoy, but I rationalized, I'm into it for millions, what's another $70
It's nice to swing the gear and stop it anywhere you wish to check clearance issues. Hope that helps.
