Why is bearing extraction a problem? I get one of my surplus allen keys and grind down the smaller end to may a sharp (sort of) spade on the end and insert it between the bearing and case and hammer out. The front one is never a problem using all the usual techniques. Re that rear bearing you might need to use a little imagination but it works. I have various allen keys ground for various types and sizes of engines.
