OK I am planning the last bits and pieces for this project.
I am thinking my setup will be:
Cheetah SE
Dreamworks Electric Gear and Brakes
JR 8411 for the flying surfaces
Jet Tech Kevlar Saddle (narrower for Bypass) tanks and Jet Tech Main Tank
Hanson UAT
PowerBox Switches
Now my question is on the Powerbox Switches:
Should I use two powerbox digi switches or one powerbox sensor switch to get the best redundancy? I have to believe that two completely separate switches has to be better. I know the Sensor Switch has two independent systems but are the truly independent in every way? What if something in that switch fails?
