RCU Forums - View Single Post - P-Effect
Thread: P-Effect
Old 08-25-2016 | 01:52 PM
  #53
OhD
Originally Posted by serious power
Hi,
Scott, I think Jim's comment was sent my way.
Jim, when I read this my mind went to the 'nothing' scene where Luke wins with nothing and Kennedy said about the fight ' he kept coming at me with a whole lot of nothing '.
However you are most likely referring to the line ' what we have here is a failure to communicate '.
If so you were correct - as said already 'my bad'
' I'm shaken it Boss, I'm shaken it '
It also put me off hard boiled eggs for a long tome
Brian
Yes, it was the line ' what we have here is a failure to communicate '.
Scott, If there is such a thing as P-factor and it causes the plane to veer to the left (the airplanes left) when you pull to vertical, and it veers to the left (the airplanes right) when you push from inverted to vertical what do you do to trim it so it goes straight in both cases, and if you can't achieve that, what rudder input will you use to correct it?
I'm sure some planes are worse than others and maybe it can't be detected on some. Gyroscopic precession and perhaps the thrust line settings could magically cancel out the P-effect but it would seem to me to be a case of luck.
Jim O
