Originally Posted by
bluelevel
Does anybody else also have the problem that the usable fuel is about 20% less than the total fuel capacity? I have JetTech the saddles & main tank and measured a total capacity of about 3.8 liters going in. Emptying the tanks on the ground I got only about 3 liters out when air bubbles started to appear from the main tank! I can see the fuel in the tank being about 1 inch high in the front (right where the slant begins), so it seems as if the tank sits at an angle. I cannot raise the front anymore, because the top of the tank almost touches the turtle deck. Does this problem go away in flight or should I change the rear tank support so that the main tank sits lower in the back?
A high flow felt clunk might improve the situation, but the diameter of the tank fitting is too small to accomodate a felt clunk.
Any other ideas?
Thomas
I don't have the saddles but have the main and wing JetTech tanks. I had to raise the front of the main tank about 5mm so when the fuel gets low I don't get bubbles in the UAT. I have JetTech heavy duty clunks and they work very well..
