Thanks for the feedback! I have been reading over the manual for the control module and was getting a bit confused on the input power. My plan was to use the same battery to power the Gear as the Turbines ECU. The manual mentioned something about the steering servo drawing too much power and causing the receiver to restart if plumbed incorrectly. It also mentioned cutting some wires to avoid this. I was planning to run my steering servo right to the receiver not through the control module. How did you wire your battery and servo?
Thanks!
