Associated Rc18t linkages are interchangeable. Removes the flimsy all-plastic push rods in the front, also allows for toe adjustment. You have to use your old ends for swapping with the camber rods though. Allows you to use a wrench instead of having a completely rounded rod which makes adjusting a lot easier!
servo has a few swap options. I personally run the Towerpro MG90S metal gear servo. That way you feel safer about removing the servo saver to help the steering.
Turnigy Trackstar and Hobbywing systems I both run. Trackstar doesn't get nearly as hot as the Hobbywing but the Hobbywing dominates by far, as far as speed goes. Hobbywing 12t 18a on 2s can run with a 1/16 E-Revo on nimh, 3s should handle the mini e-revo on 2s. Castle also has a system that works, I've yet to try it.
T-Bone racing offers bumpers. They only market for two of the vehicles but I used BX bumpers on my MT by using longer screws.
Other than Dromida hop-up kits, and aluminum upgrades, Hot Racing offers some parts for them chassis wise.
Mini E-Revo batteries would be tight, but I think they'd work with the room provided for batteries.
Still searching for diff/drive line swaps to beef them up as that is a weak point. So far nothing was found without extreme modifications.
