I see exactly what you're talking about. The arm on the steering bell crank is hitting the dang servo case!
(Btw your steering set up is almost exactly like the Evader.)
Here's what you do: Instead of mounting the servo on the forward side of the mounting tabs, mount the servo on the aft side of the tabs. The bell crank arm will clear, and the steering will work now.
