RCU Forums - View Single Post - Problem Need Help.
Old 08-29-2016 | 07:53 AM
  #69
EXT2Rob's Avatar
EXT2Rob
Originally Posted by Menaceofri
what doyou mean mount it onthe aft side? like slup it from the horn being on the right side to being on the left side? aka make it upside down?
What I meant was this: the servo is mounted to the mounting tabs toward the front of the car. That is, the tabs are behind the "ears" on the servo. Just remove the mounting screws, and move the servo so the ears are behind the mounting tabs instead of in front of them, and reinstall the screws FROM THAT SIDE. That should give the steering bell crank enough room to move.
Glad you finally got it figured out. I didn't see those barrel tabs on the servo mounts.
