RCU Forums - View Single Post - K210 Return to idle is delayed
Old 08-29-2016 | 08:22 AM
flejter1's Avatar
flejter1
Originally Posted by FALCONSNEST
Thanks everybody I relearned RC and that seemed to solve the problem. Idle RPM still fluctuates from about 32500 to 35000 so I may try changing the stability delay by a small amount. All other parameters look good.
Falconsnest,
Run your engine up to full throttle and get a reading on the PW value at full throttle. After shut down, go in the run menu and adjust the pump limit to just 20% higher than the F.T. PW. Another words, if at full throttle, the PW is 200, adjust the pump limit to 240. If the pump limit is set to high, that can cause high idle and fluctuating idle as well. Relearn RC after you make the adjustment, Start it, let it establish idle & it may take a few seconds for it to climb back up to full throttle but it will get there. Adjusting the pump limit to 20% higher will give you a better pump resolution to throttle input.
Regards,
Dirk
KingTech Service
