RCU Forums - View Single Post - K210 Return to idle is delayed
Old 08-29-2016 | 08:24 AM
FALCONSNEST
Thanks Dirk will do!
Originally Posted by flejter1
Falconsnest,
Run your engine up to full throttle and get a reading on the PW value at full throttle. After shut down, go in the run menu and adjust the pump limit to just 20% higher than the F.T. PW. Another words, if at full throttle, the PW is 200, adjust the pump limit to 240. If the pump limit is set to high, that can cause high idle and fluctuating idle as well. Relearn RC after you make the adjustment, Start it, let it establish idle & it may take a few seconds for it to climb back up to full throttle but it will get there. Adjusting the pump limit to 20% higher will give you a better pump resolution to throttle input.
Regards,
Dirk
KingTech Service
