Originally Posted by
JohnVH
I did weigh it in pieces last night, the total combined weight was right at 20lbs RTF, But Ill confirm that tonight after I see how much weight I can take back off, need to put it together outside for the final W&B check.
You are definitely running heavy according to the spec's of the plane. I wonder how the retract are going to handle the extra weight if you need to change out the retracts you might look at this one from RC Aerodyne all medal says it supports up to 22 pounds but I believe it would handle more weight with no problem and it is a local company for you and I based in Kent Wa.shipped to you for about
Legend Models 79.5" F8F Bearcat 30cc EG ARF
Model LMF8F
- Material: Laser cut balsa and ply
- Wingspan: 79.5" (2020 mm)
- Length: 60.6" (1540mm)
- Weight: 15.6 - 16. lbs (7.1 - 7.3Kg)
- Radio: 8 channel, 9 standard servos
- Engine: 30cc -40cc gas
