Originally Posted by
marc s
Hi,
The end caps have slots cut in the inner tube support which is machined into the end caps so there are around 8 bleed slots at each end that will allow air which ends up unside the inner tube to escape back into tghe outer tank whenever the DCAT is not perfectly horizontal.
If you look closely at the first picture you can see the machined slots.
marcs
I imagined it had to work that way, but I am wondering how full does the air trap need to be?
Usually air traps are effective down to about 50% or so of fuel content, while in this one it seems to me that as soon as the fuel level goes below the top of the inner tube (about 75%?), the risk of an air bubble getting stuck in the inner tube and potentially getting sucked into the engine becomes very relevant, is it so?
