RCU Forums - View Single Post - M32 Build
Thread: M32 Build
Old 09-02-2016 | 07:57 AM
Imex-Erik's Avatar
Imex-Erik
Originally Posted by RichJohnson
I got the boom mostly assembled. I have a few more things I want to solder on but that will come.
I had to cut 1/8 inch off each side of the taigen chassis to make the M4a3 hull casting from Nick Aguilar fit onto it. What a job that is. Takes a good half an hour per side. Its messy rough and tough on the face if you don't have a shield while using a dremmel cut off wheel
Here are the two small hatch tanks Im working on. The M4 and the M32B3. I have roughly fit the 3 piece tranny cover that comes in Christians M4a4 kit onto the taigen, but its not fitting well since its was made for a HL. Its too tall and long. I cut the bottom back and heated it up to reshape it a bit after grinding away lots of the material inside. Its still about 1/16 too high pushing the hull back so I am going to trim that much off the bolt bar, then reshape the bolt bar further forward on the tranny cover and sand the bolt frame braces of the 3 pieces back to shape. Should work in theory, we will see. Otherwise I will just cut down another nick tranny cover to fit like the m4 or maybe try to use the taigen, but it has a few issues preventing the hull from sitting down in place. Metal is so tough to work with.....
Looking good! Did you get that recoil unit yet? That is also the first time I've seen our Sherman chassis damaged in any way other than exhausts btw and it looks good! Your builds are always great to watch and follow. Keep it up!
