RE: Ducks on the Pond ....
JWN,
Engines should not appear in airplanes section. Only airplanes should. This is a moderator issue where our moderators need to clean up categories. This is the same stuff we deal with on the old forums. Moderators would constantly have to move stuff into the proper categories or eliminate double posts.
Double categorization IS appropriate at times though. Take a Giant Scale Piper Cub. It could go in Giant Scale and it could also go in Scale. Most of the time a single category is the only one appropriate but there are cases where more than one is proper. If things are not where they should be that is the users fault and not ours. We can only clean it up after the fact.
Would you prefer a listing option WITHOUT thumbnails for your slower connection? I'm sure we could do that.
