RCU Forums - View Single Post - Need plans for a 70" Trainer wing
Old 09-10-2016 | 04:37 AM
spaceworm
Originally Posted by Jack_K
I broke my big trainer, but I have successfully repaired the fuselage. The wing was not salvageable so I need a new one. The plane was one of the cheap ARFs from Nitro Planes. It was called the Trainer 60 I think.
The wing was 70" - 72" and had a 13" chord. It was a high wing bolt-on version.
I could build a new one with balsa and plywood or I can cut a foam wing and sheet it.
I just need some plans or a kick-start on how to create my own plans.
Any help is appreciated.
Jack
[TABLE="class: tborder user-postbit-left-user, width: 100%, align: center"]
[TR]
[TD="class: alt2"][/TD]
[/TR]
[TR]
[TD="class: user-postbit-bottom-user"]
[/TD]
[/TR]
[/TABLE]
Two sources come to mind. 1. One is SPAD, online where you can find plans for a plane and wing made of corrugated plastic, and, 2. go to OUTERZONE online and search for trainers, and pick a wing that is the size and type you want.
Probably, SPAD is the easiest and quickest, and you could use the building approach to make a wing any size you want. The stuff is tough also. Good luck.
