Originally Posted by
aquaskiman
there are two ways you can correctly set timing 1 with a degree wheel and timing light 2 a degree wheel and a tester that tells you when the plug fires. Next time I have my cowl off my Zero I will check the timing and post results. I have checked many singles and have not found even one that is timed right.
I will be interested to see your report, George.
