RCU Forums - View Single Post - new mgt 8.0 owner
Old 09-15-2016 | 05:23 AM
RCaddict80
another question for you MGT owners. i have a new set of proline big joe 40 series mounted on rims comming in today i need 17mm hex adaptors. should i get the whole hub/adaptor and nut set up like the traxxas 5353x? or should i just get like some HPI 17mm hexes that will slip right over the axles? if i decide to go with the whole hu/nut assembly will the proline rims except the larger whole that it needs to mount them? any advice will be hepfull.i already got the traxxas hub adaptors but they wont work because of the axle pin is too close to the bearing. i could either modify the adaptors and shave them doen to fit but then they might rub on the plastic hub carrier.whats your suggestion and suggestions please and thank you
