RCU Forums - View Single Post - Need plans for a 70" Trainer wing
Old 09-15-2016 | 09:55 AM
J330
I have a Telemaster kit and can make you plans for $3.00 copied by a local blueprint shop and postage to get your something in hand. I can also make a template from the ribs I have. It's a great wing design for any trainer fuselage with the flat bottom airfoil.
It's 73" wingspan, could work fine if not improve the flight you once had. Trailing edge can be had cheap from Tower, they even have the aileron tapers you'll need. http://www3.towerhobbies.com/cgi-bin...?&I=LXJD18&P=7
I also found a Kadet Senior kit, again can copy the plans for cheap, and make a template for the ribs to get you on your way. For $99 you can get the whole plane. http://www3.towerhobbies.com/cgi-bin...1p?&I=SIGA0058
