RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 09-18-2016 | 12:49 PM
  #6827
Truckracer
My Feedback: (19)
Yes that is somewhat normal for all engines that use a carb with a throttle plate. It varies quite a bit though depending on the size of the carb venturi compared to the size of the engine. You can resolve the issue by adding differential to the throttle linkage and / or by using a throttle curve in your transmitter. There has been much written about this here and in other forums. A few searches should get you more info than you ever wanted to know.
