Progress is slow but steady! I installed four hard mounting points for the satellites in the configuration recommended bu Horizon.
Im using the locking velcro to attach the sattlelites to the mounts, this stuff is great as its strong and firm, but easy to detach if you need to.
I finished off the front tray for the retract valve, servo and break valve. I will also mount the gear failsafe up here too.
TB
