RCU Forums - View Single Post - Electrifly Triton EQ Error codes
Old 09-25-2016 | 12:01 PM
Electriceddie's Avatar
Electriceddie
Originally Posted by flyinwalenda
The charger has reached the safety time limit ,displayed the error and shut down. This happens typically when charging high capacity Nixx packs at a very low amp rate. The timer can be turned off if charging Nixx packs this way.
It can also go off if a Lipo pack with a bad cell is being charged and is taking a very long time to balance. In this case you should not turn off the timer.
Hi Brian,
Is it possible that I am also just trying to charge the packs at a two low of a charge rate? If I was to raise the rate, that would charge the battery faster, correct? Then maybe it would charge the cells within the Time frame? I think I tend to set the charge rate charge a little on the low side, as to not overheat or burn up a flight pack.
Ed
