RCU Forums - View Single Post - Pilot stations
Thread: Pilot stations
Old 09-26-2016 | 01:50 AM
ETpilot's Avatar
ETpilot
Originally Posted by kenh3497
I was looking in our local Tractor Supply store at some "Cattle Panels" the other day. They are 50" tall and 16 feet long made out of 1/4 inch wire. I was thinking of cutting one in half (8 feet long) and bending it into a half circle. It would be self supporting and easily movable if needed. $10 a station is pretty cheap too!
Ken
That may be doable. First cut a rope 8' long and shape it into the U. Make sure it provides an adequate size station. For the open end of the U panel get some angle iron and weld a, U shaped, support bracket. Weld the wire to the inside of the vertical angle. For the bottom of the bracket weld ithe angle with one side down. This will dig into the dirt and help hold it in place.
Come mowing time, tilt the station and drag it out of the way. Once mowed, drag the station back into the groove made by the bottom angle piece.
May work.
