Thanks mate! I currently have the board set up as (RX)-(TK) ch 1 to ch1, ch2 to ch2 and so on. I have my TX on mode 2. The current functions That are as they come for me are turret turn left and right on rudder, turret fire with throttle down. Machine gun fire with throttle up and left. Engine on with throttle up and to the right. Elevator stick is back and forth movement. Ailerons don't turn the tank. Also the engine sound doesn't increase in power when throttle is applied. One last note is I have that yellow plug thingy still in on the board.
what I would like is For the Tank to turn on with a switch as I would like turret elevation on the left throttle stick.
Edit: I have it setup like you mentioned but the tank doesn't turn and the engine sound doesn't increase when throttle is applied.
