Hi Brandon - welcome to the difficult world of Clark setup - actually it isn't that bad but will take a while for you to learn. Strato is correct - follow that advice and also check the orientation of the leads coming out of the Clark Board as all the ones I have installed have the leads back to front. I reversed mine at the RX end.Make sure you have the Sony IR programmer handy and the LED set-up lead plus Clarks website instructions. Read them carefully and follow the instructions to make sure the board is initially set up correctly for your application e.g. airsoft or IR, momentum on, hull recoil on/off, servo recoil if used and a ton of other optional stuff.
Let us know how you get on
Cheers
CaptB
