Myself, I ended up replacing all of the gaskets with thin gasket sheet. I made copies of all the original gaskets, and set them aside so I could make more copies if needed at some point. I also noticed the stock gaskets would sometimes cover/be installed the wrong way, and I opened up the size of mine when I made them slightly. With all the slight changes I made, it really seemed to change the running characteristics in a noticeable way.
