Originally Posted by Tom Antlfinger;1226356d9
You are right David. I never mix Tygon with Festo Female sockets. My first photo obscured the fill fitting. It is a nipple with a 6 mm clip, not a Festo fitting. I like to run my fill lines well out of the fuse with flexible Tygon rather than PE tubing.
Cheers....TA
Tom, I wasn't suggesting for a moment that you were connecting Tygon TO the Festo, that, we know, does not work. I was just commenting on the fact that you are using Festo fittings , which some condemn and Tygon which some here say should not be used.
Really, I must stick to just one glass of red after a good days flying ( my SkyGate Hawk) which uses lots of Tygon and several Festo fittings Both in suction and pressure !
David.
