Originally Posted by
Skinny Bob
I am building a 1/4 scale BUSA J3 Cub and have found that LustreKoat Cub Yellow has very little pigment and takes many many coats to cover, my solution was apply safety yellow first which is a brighter yellow and LustreKote cub yellow as final coat. This process might help others.
Skinny Bob
I found with the Lusterkote Bright Yellow using a white primer first really helped. It is designed to go on light and not add excessive weight so multiple coats are a must.
I bought Solartex to cover my VK Models Fokker Triplane and will use either Rustoleum or Latex for the color and marking and then a satin cleacoat to make it fuel proof.
