Could be a plug seal too. Maybe it dragged a bit on landing. I had one bad Magnum that surged real bad and seemed to run hot. The crank to case was a bit tight. I could tell by touching the bottom of the motor when running. I have mentioned this before, but in the case of the new ring, it could just need a bit more run time, or change of a shim or heat range.
