Originally Posted by
N1EDM
Thanks for resurrecting this thread. I am in need of advice or assistance from anyone with K&B engines.
I have a K&B Sportster .65 that a friend gave it to me to rebuild and it's mostly in good shape. My problem is with the Needle Valve. It will not thread into the Spraybar. It is as though the HSN is just a mil or two too large to fit in. I am afraid that if I force it in it's going to gall.
I've emailed Meecoa to ask if I could send both pieces in, so that they could find a part that would fit one or the other, but so far, no reply from them.
Has anyone else run across a situation like this???
Bob
There's probably crud in the spraybar preventing the needle from going in or you have the wrong needle valve perhaps. Post a picture of your needle valve and I can tell you if it's a OEM part or a mismatch. FWIW All 4 displacements of the Sportsters use the same mixture disc/spraybar and needle valve.
