Originally Posted by
luckymacy
Geir, are you using a gyro? Also can you tell me exactly where you balanced yours out at if you are satisfied with it and how much throws you are using for takeoffs and landings and if you have a different rates for normal flying what are they as well? How much dead weight did you end up needing?
thx,
lucky
No gyro and i use the recomended CG and throws in the manual.After some flights i gave some more aileron throws and i now want to put the flap to max!
I use one flight condition,no difrent rates!
The P51 came out on 23kg and balanced With the batteries in the back so no extra weight/lead for balancing! And remember the IL150 With Electric starter is 7,5kg!
The P51 fly wery nutral and correct and i am wery happy With the airplane! a bit handfull landing on asfalt but wery Nice on grass!
Geir
