Originally Posted by
h.hibbler
I am having a problem with a K 80G that will only go up to 141 Max RPM setting in the ECU. The engine is only a year and a half old just purchased used with less than 5 hours of run time. I have a new K 80G purchased in May of this year, it has not been run. I checked the settings in the ECU and it does go up to 145K.
I Called Barry this morning and he told me he would not program the ECU to reach 145K because of safety issues. Barry also told me K 80's are 80N class turbines which equates to only 17.89lb of thrust which is just shy of 18lbs.
The specifications clearly state
Thrust: 8618 g @ 21.1° C. (19 lb. @ 70° F. )
Is King Tech representing K80 series engines as 19 lb thrust engines, when they are really 17 lb thrust engines? If this is the case we have a serious problem with them not being truly honest or sincere by providing consumers with false information. It clearly states in the owners manual and the King Tech website the K 80 is a 19 lb thrust engine.
Is there anyone else having this issue?
Hibbler,
I have an older K80 that is putting out over 20lbs of thrust. I have read in other threads that the manufacturer test runs the engines and tunes them to the thrust they should be putting out and the advertised max thrust is just a that, whether its 139,000 or 145,000. The manual just shows the max RPM the engine is not to go over, not the RPM it is to be set at. I know all my Kingtech's put out more than the advertised thrust and the RPM's vary from what the manual says. I also know that other manufacturers use some kind of formula to calculate thrust base on 15*C temp, sea level, barometric pressure and such, but all my Kingtech's put out the power they say it should. Have you put your engine on a bench and tested the output? Do you know you are not getting the proper thrust at 141,000rpm? Let us know what your real output data is before you cast stones!!
Ghostrider
