Originally Posted by
gunradd
All turbines put out different power per rpm... We do power assurance checks all the time on full scale engines for this vary reason. RPM is not thrust. It gets you in the ballpark but they are not the same on every engine.
I have seen some K180s put out k210 power and some just 180 power. Differences in the NGV vanes and turbine blades along with the compressor all change thrust.
Yes I already Know there can be some differences but we really need the Kingtech to explain why some of their engines are not at the rated RPM. Like I said if they know some K 80’s can produce 19 lb thrust at
less than 145 K they should say so and certify each engines shipped with the exact thrust that engine produced.
