The reason I brought it up is that when you move up in class, your plane needs to have a higher thrust to weight ratio to do the sequence correctly.
ORIGINAL: Shadow-RCU
Geistware:
I have only competed in one event and that was in Basic. I understand that some events that have a limited number of contestants will eliminate the Basic and only have the Sportsman.
Thanks everyones, I appreciate the help and advise.
Randy
