The FG60 manual says 15:1 for breakin.
Once the engine is broken in the low speed needle has a much bigger effect than the high speed needle. Adjust the low speed needle for good idle and good transition to high rpm. Adjust the high speed needle for best peak rpm (lean to peak and then richen just a little).
