Quoted from the CanAm international RC Tank Club (Ontario Canada), Yes a plug for us
Originally Posted by Glen B
Jammed into the Jadgpanther
Side by side with the 2000 HL Ni-Cd.
The venom 4600 is slightly longer and while the battery cables are thicker, they are super soft and flexible.
You will usually be good with most 6 cell NiMH batteries, they may be a bit tight, but they should all fit.
Depending on how handy you are at modifications to the hull/plates/plastic work, you find a few who replace the upper/lower hull screws with magnets, relocate all the switches/potentiometers and seal the lower hull up as best they can.
