The standard larger white connectors are called JST-XH plugs and are the same as used on Lipo balance plugs. The servo connectors are sometimes called Dupont and standard servo pins have a 2.54mm pitch. The smaller Tamiya connectors are called Molex micro-latch connectors by Digikey. Hopefully this helps
