i was trying to hide the linkages in the fuse to get it as close to scale as i could
the tork rods that andy gave me in the kit i believe came from the avonds f15 as they are mounted in a differant way using bearings on a mounting plate
so i thought i could use the same method but the tork rids are 90mm long from the tailerons to the control horn which gave me around 10/15mm of play
at the trailing edge without using any force ,which i thought was totally unacceptable ..
