Setup below from the THD Manual
1. Heard this airplane requires a lot of down elevator while inverted, where as per manual the deflection asked to set is less than the UP stick movement?
2. What we know that to have axial rolls & reduced drag we always setup aileron going up with more deflection than the aileron going downwards, however it looks opposite in the manual! Or may be negative 17% differential compensates it?
